NH TN75A
   / NH TN75A #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I am looking at a TN75A with a loader and have a few questions. 1. With the current incentives from NH, what is a good price for this tractor and a loader? 2. What problems have they had with this tractor - there is not such thing as a perfect tractor - or at least I have not owned one.
   / NH TN75A #2
4wd? Which transmission? How many remotes?
I own a 75 and so far its been pretty good. Dont have that many hrs on it though. In general it seems the TN series is very good. There are several other TN owners here that can better address how well they wear over time.
   / NH TN75A #3
My TN65 is a little different then the 75 but I have owned it new since 1999 and it has over 1100 hours currently. You already know how I use mine from your other post but I had a few problems when the TN was first released here and NH took care of them. Those problems are no longer an issue. Other then my first year issues the only problem I have had (that I can remember) is a Neutral Safety Switch (commonly referred to as a NSS on here) failed. It is a rather cheap part to replace, take out two screws and remove the electrical connecting plug and the old one is out, put the new one in and your on your way again. The only down side is the one that died on me could only be accessed (easily) by removing the left rear tire which can be dangerous when loaded but generally is scarier to think about then to actually do. If you ever have this issue with any loaded tractor tire just jack up the back and block the axle so the weight is off the tire but the tire is on the ground still. Remove the lugs and roll it over to a post against the wall and let it lean against the post. If you have a helper this is a rather simple and uneventful chore.
New Holland has been updating and modifying the TN series since they were released and as problems come up they adapt the tractor to address them. Most of the old problems on here should not be a problem on a new model but I do not have a new one to know how it holds up.
   / NH TN75A
I am looking at the fwd and the 12x12 transmission.
   / NH TN75A #5
If you go to the post titled 'Pricing TN70A' in this forum (not far down the list) I outlined the price I paid for my 75. That might help some w/ your calculations. Your location might also dictate the final price as some areas are traditionally more expensive than others. Using the search function may also help...I know there are several others w/ TNs here and there have been several queries on pricing.
LANESHARK LS3 LOT IDENTIFIER 148 (A53084)
LANESHARK LS3 LOT...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2020 JOHN DEERE R4023 LOT IDENTIFIER 87 (A53084)
2020 JOHN DEERE...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
