NH TN70 power steering?
   / NH TN70 power steering? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbors TN70 power steering abruptly stopped operating while cutting hay. Remote hyd & pto still operate. He stated it hadn't be many hrs since hyd filter was changed & hyd fluid level is at full mark. Any ideas?
Thanks,Jim
   / NH TN70 power steering? #2
I'd start at the pump. ASSUMING it's all mechanical transmission(?) then all this pump does is supply steering. Both steering and hydraulic pumps are supplied from a common suction and filter. If one pump works, the problem isn't filter or supply.
Loosen the two bolts holding the pressure side flange to the steering pump a couple threads. Start it up for a few seconds and see what happens. If the pump is working it will make a mess in a few seconds. These pumps usually don't loose prime while operating but who knows? If it doesn't produce after a few seconds, you might want to remove it and check the drive. The shaft/gear that drives the pumps has been known to snap the tangs that mate with the pump coupling.
Harry
Thanks for reply. I'll relay what you stated to neighbor.
Jim
Neighbor told me that nut was off of cyl rod letting piston loose.date: Neighbor told me that nut was off of cyl rod letting piston loose.
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A57880)
2019 KENWORTH T680...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
