NH TN70 power steering?
   / NH TN70 power steering? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbors TN70 power steering abruptly stopped operating while cutting hay. Remote hyd & pto still operate. He stated it hadn't be many hrs since hyd filter was changed & hyd fluid level is at full mark. Any ideas?
Thanks,Jim
   / NH TN70 power steering? #2
I'd start at the pump. ASSUMING it's all mechanical transmission(?) then all this pump does is supply steering. Both steering and hydraulic pumps are supplied from a common suction and filter. If one pump works, the problem isn't filter or supply.
Loosen the two bolts holding the pressure side flange to the steering pump a couple threads. Start it up for a few seconds and see what happens. If the pump is working it will make a mess in a few seconds. These pumps usually don't loose prime while operating but who knows? If it doesn't produce after a few seconds, you might want to remove it and check the drive. The shaft/gear that drives the pumps has been known to snap the tangs that mate with the pump coupling.
Harry
Thanks for reply. I'll relay what you stated to neighbor.
Jim
Neighbor told me that nut was off of cyl rod letting piston loose.date: Neighbor told me that nut was off of cyl rod letting piston loose.
2121 (A51244)
2121 (A51244)
Swict Q.A 60" Bucket (A50121)
Swict Q.A 60"...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2023 Toyota Highlander Hybrid SUV (A50324)
2023 Toyota...
