NH TN70 Hand Barke Sticking
   / NH TN70 Hand Barke Sticking #1
darenlewis
Gandeeville, WV
MF 6250 HD and NH TN70
I have a 2003 NH TN70, I am the original owner. When I set the hand/parking brake and then go to release it the lever in the operator area will perform normally. However, I have to manually push the arm attached to the transmission casing o get the brake to release. Has anyone else encountered this problem and how did ou solve it?
I need the parking brake here in the hills of WV as one could guess.:laughing:
   / NH TN70 Hand Barke Sticking #2
Crawl under the tractor with your favorite aeresol penetrant. Disconnect the linkage and swing the park brake lever down as far as you can. Spray the area where the operating rod enters the housing. Work the lever throughout its full range of motion repeatedly, spraying the referenced area as you go. It should free up. Don't let the tractor roll over you while underneath it.
RickB - thank you for the help. I will let you know if I do it right(I am a retired Banker and Geek).
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Diamond (A53117)
Diamond (A53117)
