NH TN70 Hand Barke Sticking
   / NH TN70 Hand Barke Sticking #1
darenlewis
Gandeeville, WV
MF 6250 HD and NH TN70
I have a 2003 NH TN70, I am the original owner. When I set the hand/parking brake and then go to release it the lever in the operator area will perform normally. However, I have to manually push the arm attached to the transmission casing o get the brake to release. Has anyone else encountered this problem and how did ou solve it?
I need the parking brake here in the hills of WV as one could guess.:laughing:
   / NH TN70 Hand Barke Sticking #2
Crawl under the tractor with your favorite aeresol penetrant. Disconnect the linkage and swing the park brake lever down as far as you can. Spray the area where the operating rod enters the housing. Work the lever throughout its full range of motion repeatedly, spraying the referenced area as you go. It should free up. Don't let the tractor roll over you while underneath it.
RickB - thank you for the help. I will let you know if I do it right(I am a retired Banker and Geek).
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
UNUSED FUTURE SSJ430J WALK BESIDE JAW CRUSHER (A51247)
UNUSED FUTURE...
