NH td80d clutch cable
   / NH td80d clutch cable #1
Arnold_Ziffel
poughkeepsie, Ar
kubota m4030su john deere 2955
The clutch cable on my td80d has jumped out of its slot on the bracket under the cab, plus the adjustment nut needs tightened up.. Fricken hogs have torn up my hayfield. Am I going to have to drop the fuel tank to get at it?
   / NH td80d clutch cable #2
Yes you are going to have to drop the fuel tank. If you need to get your hand in there further than just dropping the tank, you can remove the bolts for the front cab/floor mounts and loosen the back, tilt up the cab/floor from the front of the transmission a few inches being careful that you don't pull or stretch anything
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
