NH td80d clutch cable
   / NH td80d clutch cable #1
Arnold_Ziffel
poughkeepsie, Ar
kubota m4030su john deere 2955
The clutch cable on my td80d has jumped out of its slot on the bracket under the cab, plus the adjustment nut needs tightened up.. Fricken hogs have torn up my hayfield. Am I going to have to drop the fuel tank to get at it?
   / NH td80d clutch cable #2
Yes you are going to have to drop the fuel tank. If you need to get your hand in there further than just dropping the tank, you can remove the bolts for the front cab/floor mounts and loosen the back, tilt up the cab/floor from the front of the transmission a few inches being careful that you don't pull or stretch anything
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2016 JOHN DEERE 3032E LOT NUMBER 97 (A53084)
2016 JOHN DEERE...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
