3-Point Hitch NH TD5050 - arms will not go up ???
   / NH TD5050 - arms will not go up ??? #1
zbig
canonsburg, pa
nh td5050
I am new to the site and TD5050. Operated BB for 1 h all ok and now 3 point hitch will not work. Any suggestions will be appreciated. John
   / NH TD5050 - arms will not go up ??? #2
Did you or someone depress the Lift-o-matic lever (big plastic switch/lever on RH fender)? It allows you to make your depth setting and your lift settings, then you push the lever in to let the 3 point down. Flip the small switch on the mechanism allows the hitch to go to upper position.
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
