3-Point Hitch NH TD5050 - arms will not go up ???
   / NH TD5050 - arms will not go up ??? #1
zbig
canonsburg, pa
nh td5050
I am new to the site and TD5050. Operated BB for 1 h all ok and now 3 point hitch will not work. Any suggestions will be appreciated. John
   / NH TD5050 - arms will not go up ??? #2
Did you or someone depress the Lift-o-matic lever (big plastic switch/lever on RH fender)? It allows you to make your depth setting and your lift settings, then you push the lever in to let the 3 point down. Flip the small switch on the mechanism allows the hitch to go to upper position.
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2018 PJ 40T/A GOOSENECK TRAILER (A50854)
2018 PJ 40T/A...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
