NH TC45DA bouncing 3pt
   / NH TC45DA bouncing 3pt #1
PhilFH
central, indiana
NH TC45DA
hello
I was wondering if anyone has had an issue with the 3pt on a NH TC45DA bouncing when under load such as with a bush hog raised? This is most noticeable when it is parked regardless of the idle speed. I don't notice it when I am moving forward or reverse. The tractor has a HST which seems to be working fine. I appreciate any help you can give.
Phil
RD,
Thanks the link worked and it sounds like the same issue, I will check to see if the flow control valve prevents the arms from dropping and if not I will look into the repair described in the other post.
Phil
BELSHE DT-235 (A53843)
TOOLBOX (A53843)
TOOLBOX (A53843)
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
