NH TC40DA 2005 Knockn' and blown' Smoke
   / NH TC40DA 2005 Knockn' and blown' Smoke #1
lloyd430
Central, NY
NH 2005 TC40DA
Originally posted in NH looking for more help!!!!!
Hey folks I have been having an issue with my engine. When she warms up and the rpms are at 2500+ after a couple on minutes-literally at the 1:16 part in the video all heck breaks loose. Knocking smoking, when I idle her down it stops and clears up till I raise the rpms up again. Smoke is fuel - not anti freeze. Oil is clean and I did a fuel filter change a little sediment in the bottom but not bad. There if black floaters in the fuel line (bacteria) and I have also done a whole fuel dump, 13 gallonsTC40DA hydro smokn' and knocks'. Here is the link to the video:
TC40DA horrible knock and smoke - YouTube thanks for ANY help!
Update I have removed the fuel tank thoroughly cleaned it, it was nasty, cleaned out the line, replaced the fuel solenoid and still the same! I think the only thing left is to take it into the dealer and have them check the injectors and the injection pump.......I'm guessing a $2000-2500 bill, any ideas......I even built a separate fuel cleaner to to polish any fuel that goes into the tank I don't want to clean the tank ever again! Also I cleaned my fuel cap- that was nasty as well. Everyone says it's starving for fuel, to me the only thing left is the pump and injectors.....
   / NH TC40DA 2005 Knockn' and blown' Smoke #2
Have you tried loosening a line, AT THE INJECTORS 1 at a time while its knocking?? IF/WHEN the sound changes or quits, you found your suspect cylinder.. just move THAT injector to another hole, furthest away & see if the problem follows the injector..
IF there is no change in sound.. chances are, its a rod..
Thanks I'll give that a try tomorrow, I give up for today.
   / NH TC40DA 2005 Knockn' and blown' Smoke #4
Check if the ign switch do not stuck in the heat posision and give power to your thermostart ?
I was just thinking about this.....this process would narrow down the injectors but it would necessarily rule out the injection pump???? Or am I thinking about this too hard
Good call but the switch is fine- I can go all day below 2600 rpms with no problems but once I do ........
   / NH TC40DA 2005 Knockn' and blown' Smoke #7
1 thing at a time Lloyd.. 1 thing at a time..
IF you loosen the line AT THE INJECTOR your removing the fuel being delivered to the injector.. THEN you can narrow it down by moving THE INJECTOR. & AFTER those checks, we'll move on..
Ooohhh I get it now!!!!!! Thanks for the tip!
OK this is what i found....... a little humble pie........., when I check the oil level before I was on uneven ground, today when I check ed it on level ground I was WAY too high, so I drained the oil and I was supposed to have 6+ quarts I had 8.5-9 quarts in it!!!!! It seemed thin, so here is my theory, the fuel pump is bad/going bad and I am pumping fuel into my oil pan via the pump. I am going to take a new sample of iol tomorrow to have it tested for diesel, if there is then its the $100 pump, if there isn't and my boy screwed up and put too much oil in. When I put new oil in I ran her at 2600 rpms for over 15 minutes with no issues. I will keep you posted!
   / NH TC40DA 2005 Knockn' and blown' Smoke #10
I had a friend who inadvertently put too much oil in his atv. Precisely the same symptoms. He drained some oil and problem solved.
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
2012 Benlee TABM40 Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
2012 Benlee TABM40...
