NH TC30 not turning over
   / NH TC30 not turning over #1
double hunter
Ford 1715
I bought this tractor last week and i am having some issues with cranking,,it will not turn over,,been cranking since I bought but got on it this morning and it want done nothing,,i was running it yesterday, put it under the carport and this morning nothing,,yesterday when I first cranked it , it acted like it wanted to quit a couple times times to no fuel,,I took the side plate off to get to the switch and checked all that with a test pick and I the switch is ok,,all lights are coming on the dash, the fuel solenoid is not operating,,i operated the pto levers to make sure they were not operated,,what can I check next,,any help greatly appreciated
   / NH TC30 not turning over #2
I would check all the safety relays, especially the seat switch. My TC29DA seems to start easier when the shift is in the neutral between 2nd and 3rd range rather than neutral between 1st and 2nd.
   / NH TC30 not turning over #3
I'd ask the previous owner.
I kinda sorta found my problem,,its gonna be in the safety switch wiring under the rear fender,,was looking at the pto switches and moving some of the wires around and it started cranking,,im sure it will be back,,i gonna get someone to hold the switch on while I move the wires and see if I can isolate it
   / NH TC30 not turning over #5
DH- Good luck. If I remember correctly that safety switch wiring is pretty exposed and sticks, etc can get in there and disconnect/break wires.
   / NH TC30 not turning over #6
Did you ever isolate your problem? I had the same problem and found the problem to be the "Seat Safety Switch Timer". It's the rear relay of several mounted below the seat on the left side. I cracked open the relay to find a small circuit board inside. Upon re-attaching the wiring I was able to duplicate the problem by "tweaking" on the circuit board. With ignition sw. ON I could hear a solenoid clicking in the engine compartment. Having previous experience with electronics and soldering, I re-soldered every connection point on the circuit board and resolved the problem. Hope this helps.
Current enters the seat safety switch timer. The
seat safety switch controls the ground path for
the seat safety switch timer. With the operator
seated, the seat safety switch closes to
complete the ground path to the seat safety
switch timer. This activates the seat safety
switch timer completing the ground path to the
kill relay. The kill relay energizes and latches.
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
John Deere 350 PTO Manure Spreader (A51039)
John Deere 350 PTO...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
