NH TC30 electrically dead
   / NH TC30 electrically dead #11
That,s why to properly check a battery you need to do a load test on it. Resting voltage doesn,t mean much.
   / NH TC30 electrically dead #12
I know on my old Case IH, which was also a New Holland build, there was a fuse in a location that was obscure and hard to find.
The only way I found it was looking at a schematic online. It's a main fuse right around the starter, kills everything. It was also kind of hard to get to.
I highly doubt it is the battery it would probably give you something,, a click a flicker of light, if just a weak battery.
As already mentioned, I would try the connections, find a schematic for the all the fuses, and take the battery to a Napa and have them check it
Since you were using the PTO that sounds like a strong possibility that a switch is not making connection.
   / NH TC30 electrically dead #13
Don't underestimate the effect of resistance in a circuit. I have a small fishing boat with a deep cycle battery powering the running lights. What possibly could stop a big, bad deep cycle battery from lighting the lamps? Oddly enough, I was getting good voltage at the terminals, but there was not enough current to light the bulbs. I hosed all the connections with CRC 2-26 and bang the lights came on! I then went again and cleaned them, lubed with silicone grease for protection and have not had a problem since.
   / NH TC30 electrically dead #14
True, 12.6V (or 12.5V) doesn’t tell you the amount of available charge, but it tells that all cells are 2.1V and available, that is, it’s not resting at 10.5 volts with a shorted cell.
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
UNUSED RAYTREE RMRB72 72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (GRAY) (A57193)
UNUSED IRANCH...
2017 BOBCAT S770 SKID STEER (A52707)
2017 BOBCAT S770...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
TANK MANIFOLD (A55745)
