NH TC30 - add oil pressure gauge
   / NH TC30 - add oil pressure gauge #1
PAProbe
La Jose
None
Has anyone on here added an aftermarket oil pressure gauge to their New Holland TC tractor? I need to know what thread size the oil pressure switch is. I screwed out the factory oil pressure switch and tried to screw in my 1/8 NPT oil line and found that it is not NPT.
Anyone done this before?
Update - I found info here - http://www.tractorbynet.com/forums/new-holland-owning-operating/235218-new-gauges-1900-a.html
Someone installed a temp and oil gauge and did not need metric to NPT adapters. One user mentioned that his Ford 1700 was NPT and that the japanese tap shallower than US so the threads tighten up after 1 turn usually.
I had a test gauge I was trying to turn in and it did start but was immediately tight in the threads so I assumed it was different. I may try to turn it in slowly and back it to to check for any thread damage for permanently installing something.
   / NH TC30 - add oil pressure gauge #3
Most Shibaura (Ford/new Holland compact) engine oil pressure senders are 1/8" BSPT which is one pitch per inch different than 1/8" NPT. Some guys notice the difference, some don't.
OK Thanks.
I guess the Honda car guys run into this alot.
Here is a picture of the thread difference. The NPT has a sharp edge on the thread while the BSPT is more rounded. Most of those guys run a NPT tap over the BSPT threads and it works fine.
http://honda-tech.com/attachments/forced-induction-16/307934d1359360052-1-8-pt-will-thread-into-1-8-npt-seal-dsc05550.jpg
   / NH TC30 - add oil pressure gauge #6
OK Thanks.
Running a -28 tap or die over a -27 fitting is a lousy way to get around buying the right fitting. it is your dime.
   / NH TC30 - add oil pressure gauge #7
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
PALLET OF (2) TRIPAC THERMOKING UNITS (A50854)
PALLET OF (2)...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
