NH TC30 - add oil pressure gauge
   / NH TC30 - add oil pressure gauge #1
PAProbe
La Jose
None
Has anyone on here added an aftermarket oil pressure gauge to their New Holland TC tractor? I need to know what thread size the oil pressure switch is. I screwed out the factory oil pressure switch and tried to screw in my 1/8 NPT oil line and found that it is not NPT.
Anyone done this before?
Update - I found info here - http://www.tractorbynet.com/forums/new-holland-owning-operating/235218-new-gauges-1900-a.html
Someone installed a temp and oil gauge and did not need metric to NPT adapters. One user mentioned that his Ford 1700 was NPT and that the japanese tap shallower than US so the threads tighten up after 1 turn usually.
I had a test gauge I was trying to turn in and it did start but was immediately tight in the threads so I assumed it was different. I may try to turn it in slowly and back it to to check for any thread damage for permanently installing something.
   / NH TC30 - add oil pressure gauge #3
Most Shibaura (Ford/new Holland compact) engine oil pressure senders are 1/8" BSPT which is one pitch per inch different than 1/8" NPT. Some guys notice the difference, some don't.
OK Thanks.
I guess the Honda car guys run into this alot.
Here is a picture of the thread difference. The NPT has a sharp edge on the thread while the BSPT is more rounded. Most of those guys run a NPT tap over the BSPT threads and it works fine.
http://honda-tech.com/attachments/forced-induction-16/307934d1359360052-1-8-pt-will-thread-into-1-8-npt-seal-dsc05550.jpg
   / NH TC30 - add oil pressure gauge #6
OK Thanks.
Running a -28 tap or die over a -27 fitting is a lousy way to get around buying the right fitting. it is your dime.
   / NH TC30 - add oil pressure gauge #7
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
