NH TC29D tach & hour meter quit when hot
   / NH TC29D tach & hour meter quit when hot #1
jelmore
Adolphus, KY
NH TN75DA, Kubota L5740
Hello, new user here with a question. My tc29d tach and hour meter quits working after about 30 minutes when mowing. I can shut down and wait 5 minutes and restart and it will work for about 30-45 seconds and quits again. Seems as something in the cluster gets hot. I have removed the cluster and taken it apart to look for any problems and found none. Any one have a diagram on the cluster operation, what componets are common with the tach and hour meter. I'm a retired electronics tech so component replacing no problem. I would like to repair it instead of replacing it. My local dealer quoted $358 for a replacement. Thanks for any reply and sorry for the long post.
Thanks, John
   / NH TC29D tach & hour meter quit when hot #2
...the tach on my TC35D quits occasionnaly in the cold !!!!
I think it may be a slight crack in the board. Not really that big of a deal though. I can usually get it to work again with a restart.
Works fine all through the warm months !! /forums/images/graemlins/confused.gif
   / NH TC29D tach & hour meter quit when hot #3
jelmore, When I first got my TC40D, my tach wasn't working at all. The only problem was the connection at the alternator was loose. Maybe you have a thermal connection break. Try cleaning the connection up and closing the connector clip up a bit for a tighter fit. Those kind of intermittent problems are the hardest to trouble shoot. Good luck!
stonefox
Thanks, I will try that.
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
