NH tc24d no reverse or forward - hydro oil leaking out under pressure
   / NH tc24d no reverse or forward - hydro oil leaking out under pressure #1
blazing bee
new holland TC 24 D
I cracked the middle housing that supports mid mount mower . This is the the 3 rd time this has happen , i never had a problem like i am expercinging now. After starting tractor the oil pushes through oil filter rubber gasket , so i tighten that further and then it blew through rubber coupling that joins oil cooler , so i retighten that and then it explodes underneath where metal hydro tubing joins together with rubber coupling . My symptoms are no reverse or forward , bucket and pto works fine . I think its a blown valve body one of the oil seals are bad but not sure on that . Looking for help . What i have done is to drill a hole in bottom of oil filter and ran a hose to back of tractor where you fill up hydro oil so i can a least run engine . It keeps it from exploding oil from gasket or rubber couplings
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
