NH tc24d no reverse or forward - hydro oil leaking out under pressure
   / NH tc24d no reverse or forward - hydro oil leaking out under pressure #1
blazing bee
new holland TC 24 D
I cracked the middle housing that supports mid mount mower . This is the the 3 rd time this has happen , i never had a problem like i am expercinging now. After starting tractor the oil pushes through oil filter rubber gasket , so i tighten that further and then it blew through rubber coupling that joins oil cooler , so i retighten that and then it explodes underneath where metal hydro tubing joins together with rubber coupling . My symptoms are no reverse or forward , bucket and pto works fine . I think its a blown valve body one of the oil seals are bad but not sure on that . Looking for help . What i have done is to drill a hole in bottom of oil filter and ran a hose to back of tractor where you fill up hydro oil so i can a least run engine . It keeps it from exploding oil from gasket or rubber couplings
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52128)
2022 JCB 3TS-8T...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
Backhoe Attachment (A50322)
Backhoe Attachment...
2019 Harley Davidson (A50324)
2019 Harley...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
