NH T5060 coolant
/ NH T5060 coolant #1
Ausmac
Proserpine QLD
Massey Ferguson 188, JD 2130, Fiat 650
Hello all. I’ve just bought a new to me New Holland T5060. Lovely tractor and even has air con!
I’m looking for the correct coolant to use in these NEF engines.
The manual says Ambra Agriflu but I’ve never heard of it. Unless there’s a new name under CNH?
All research points to a coolant that meets ASTM D-3306 spec and is red in colour. No info about whether to use IAT or OAT?
Every other tractor I’ve owned although older, has used standard green from any old shop and I’m not really into getting ripped off buying genuine fluids as they’re all made by a regular oil company anyway.
Any info much appreciated.
/ NH T5060 coolant #2
New Holland 1 Gal Extended Life OAT Coolant / Antifreeze – Premix 50/50 MAT 3724 Part # 73344307
73344308 2.5 Gallon
For use in Tier 4 Final/Stage V engines and earlier.
/ NH T5060 coolant #3
Hello,
I have a 2017 New Holland WM60 and I use Valvoline Zerex HD Nitrite Free Extended Life (Yellow). I also attached the Data sheet. It is ASTM D-3306 approved.
scott
  • US_Val_ZXExtendedNF_AFC_HD_EN_Komatsu apprvd.pdf
/ NH T5060 coolant
Thank you for the advice. It doesn’t seem like that’s available in Australia but I will look for a coolant that is ATSM 3306 and also nitrate free which I think is key for aluminium components.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2016 John Deere 6155R (A64119)
2016 John Deere...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
