NH T4.90 Heat/AC Problem
/ NH T4.90 Heat/AC Problem #1
Jackfr
Plymouth, MA
NH WorkMaster 33 Ford F5000 NH T 4.90 Ford 2110 JD555B
Has anyone had problems with a 2017 NH T4.90 Heat/AC? We replaced the Heat valve last year because there was no heat and valve was stuck closed. It worked fine until now controlling the amount of heat/AC. Now it is stuck open so full heat and no AC. It's a real PIA to get to the heat valve to replace it again. I've checked all the fuses for the controls all appear to be good. Any suggestions?
/ NH T4.90 Heat/AC Problem #2
You could install a manual water valve, there are many available hand screw type or cable operated.
We used them in trucks as a low cost repair.
I've been trying to find one but no luck so far. The hose is 14mm ID according to the parts book. Which is a little larger than a 1/2" and smaller than a 5/8".
/ NH T4.90 Heat/AC Problem #4
If you are committed to a manual valve you could disconnect the hose and test fit a 5/8th nipple , if to big than Yeah 1/2 inch(14mm) is a odd size. Guess its a trip to the local hardware to make your own.
Recommend to use brass.
3410 (A47477)
3410 (A47477)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59905)
2020 INTERNATIONAL...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab Pickup Truck (A59230)
2018 Chevrolet...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
POWDER RIVER CATTLE SHUTE (A60430)
POWDER RIVER...
EZ loader trailer (A56857)
EZ loader trailer...
