NH T30 fuel leak at the injector pump
   / NH T30 fuel leak at the injector pump #1
double hunter
Ford 1715
Got a new to me NH TC30,,ive got a very slight fuel leak where the lines come out of the injector pump,,,leaking out from under the flat plate that holds the conector down,,was gonna try and tighten it but the the nut is a 5 sided pentagon shaped nut,,,went to a couple parts houses lookng for a socket and they had no clue,,probably a specialty tool at the decide,,any ideas,,tried everything in my tool box to no avail
   / NH T30 fuel leak at the injector pump #2
Tightening it down WILL NOT HELP.
The orings are hard & leaking..
This is something you DO NOT want to mess with..
The flange where its leaking, is the equal delivery adjustment for each cylinder..
IF you don't get it right, the engine wont run smoothly.. & if you put it in backwards, the cylinder wont fire..
There are TINY parts in there, that if lost, will cause you a whole bunch of grief..
I just sent 1 back to a customer that lost A BUNCH of parts & it was gonna cost him as much to FIX HIS, as it was to buy a new pump..
so he opted for THAT.
I'll send you a PM..
   / NH T30 fuel leak at the injector pump #3
They are tamper proof bolts, for a reason..
ok that answered my question,,got a pump guy close to me thta is really good,,thanks
   / NH T30 fuel leak at the injector pump #5
Ya might wanna find out what he charges FIRST..
Did you get my email? MOST shops charge around 600.00..
It might be WELL WORTH a few $ in "shipping".. if ya know what I mean.
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
