Hi all,
This is my first post to the site. I bought a New Holland T2310 Boomer in 2008 and it has been a great tractor except for one issue. When it is 10 degrees or colder or thereabouts it will start pretty easy without plugging in. The problem is after it starts it will start revving up uncontrollably, even past it's max speed. So when I start it I have to stand there and watch it so it doesn't blow itself up. I can stop it and restart it several times and it does the same thing. It has blown the hydraulic filter seal out two times and that is a pain with oil all over the floor.
The first year or so I had it I kept it in the heated part of the shop but the following years it has been in the unheated side. When I told New Holland what was happening they really didn't have a clue of why until the second oil filter blew and so did I. Then they came up with NH Bulletin that said something about the oil was too thick. I have used Shell Rotella T 15W40 in all my six or seven other Ford diesels with no problem. New Holland said I should use 10W30 and that should fix my problem. Well it didn't. Even though it will easily start with the glow plugs it still has to be plugged in to the wall socket for the block heater. That's not really unrealistic for my other tractors but there is something miss-engineered in this Shaurabaura (sp) compact diesel.
My short term trial for the rest of this winter is Shell Rotella T6 Synthetic in 5W40. I have used synthetic oil in my Chevy pickup and golf cart and they both start so much easier so I thought as a last resort, why not try it in the Boomer.
Oh, by the way when New Holland finally admitted there was a problem it was just after the warranty ran out.
I have looked on the net since this started and never found any info, so I thought I would give this forum a try. If anyone has had a similar problem with a New Holland or similar compact diesel engine of this type I'd like to hear your problem and maybe a solution. I'll check this site every day or so and also report any progress on my end. The new Rotella T6 goes in tomorrow. Thanks, Falkster in Indiana.
