NH T1530 tractor information on routine maintenence and pto issue...
   / NH T1530 tractor information on routine maintenence and pto issue... #1
Amherst Wisconsin
Ford 641 / 1963 Fordson Super Major
Hi
I have a NH T1530 with a pto issue. Lever is stuck. No manual.
Anyone with experience on this pto issue?...
About 500hrs on it.
Also, if there is a link to online information on hours of service and maintenance, or any information on that would be appreciated.
How often should you change hydraulic fluids and filters. Front axle oil?
   / NH T1530 tractor information on routine maintenence and pto issue... #2
Did you ever get any resolution with this? I am experiencing the same issue with the same tractor.
Yes. The lever that was frozen up tight.
by applying PB blaster and gently tapping on it, it eventually started to loosen, and was completely fine.
It is good practice to use everything move every lever at least spring and fall to ensure everything is moving and working as needed.
   / NH T1530 tractor information on routine maintenence and pto issue... #5
I'll give it a shot before I tear into it.
Thanks for the response
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
