Backhoe NH LB-620 issues
/ NH LB-620 issues #1
alex 1375
1986 NH LB-620
Hello everyone ,I have a 1986 NH LB-620 BACKHOE THAT IS GIVING ME A HEADACHE.FOR SOME REASON WHEN I START IT NOW ;I TURN KEY ON,HIT GLOW PLUG BUTTON 10-15 SEC 1/3 THROTTLE ,AND IT STARTS AND RUNS STRONG FOR ABOUT 2-5 MIN. THEN THE VOLTAGE GAUGE DROPS LOW,BARELY IN THE GREEN AND I HAVE NO CONTROL OF THE THROTTLE ANYMORE-MOVING IT DOES LITTLE TOO FOR THROTTLE RESPONSE, AND THEN THE ENGINE SHUTS OFF.CYCLE THE KEY,HIT THE GLOW FOR A SEC ,THEN SHE FIRES UP FOR A COUPLE OF SECONDS AND SHUTS DOWN,ON AND ON.I HAVE CHECKED FOR WATER IN DIESEL TANK BY POPING THE DRAIN PLUG-A LITTLE SEDIMENT,RUST AND SOME DROPS OF WATER.NOT ENOUGH TO KEEP STALLING THE ENGINE AND NOT LET THE ALT. CHARGE! THE MECHANICAL FUEL FUMP FELT ON OCCASION FOREVER TO PRIME,SO I WIRED IN A 4-7 PSI ELECTRIC PUMP,CLOSE TO THE TANK ABOUT A FOOT AWAY AND I'M STILL GETTING THE SAME THING! THE BATTERY IS MAYBE OVER A YEAR OLD ,BUT LESS THAN TWO.AND THE ALTENATOR IS NEW ALSO.IVE BEEN CHECKING ALL GROUNDS,CONNECTIONS,PLUS I HAVE AN OWNERS MANUAL WITH WIRING DIAGRAM ,THERE IS NO FUSE BOX-ONLY 2 15AMP CIRCUIT BREAKERS 1IS FOR THE ELECTRICAL SYSTEM-SENSORS,STARTING,CHARGING.THE OTHER IS FOR THE BLINKERS,4 WAY AND WORK LIGHTS.I HAVE A FEELING IT MAYBE RELATED TO THE GAUGES OR THE CONNECTORS FOR HARNESS.IS THERE ANY SAFETY FEATURES IM MISSING?I KNOW I CAN START IT IN GEAR ALSO, AND I DISCONNECTED THE TURN FLASHER RELAY AND LIGHTS,IT NEEDS ALL NEW LIGHTS ANYWAY.ARE THOSE HARNESSES KNOWN FOR PROBLEMS?THIS IS MY OWN AND I USE IT ALL THE TIME ,ITS REALLY JAMMING ME UP.ANY SUGGESTIONS PLEASE!!!!
Pig Statue (A64557)
Pig Statue (A64557)
Rooster (A64557)
Rooster (A64557)
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2022 EZ-GO ELITE...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
