Backhoe NH LB-620 issues
   / NH LB-620 issues #1
alex 1375
1986 NH LB-620
Hello everyone ,I have a 1986 NH LB-620 BACKHOE THAT IS GIVING ME A HEADACHE.FOR SOME REASON WHEN I START IT NOW ;I TURN KEY ON,HIT GLOW PLUG BUTTON 10-15 SEC 1/3 THROTTLE ,AND IT STARTS AND RUNS STRONG FOR ABOUT 2-5 MIN. THEN THE VOLTAGE GAUGE DROPS LOW,BARELY IN THE GREEN AND I HAVE NO CONTROL OF THE THROTTLE ANYMORE-MOVING IT DOES LITTLE TOO FOR THROTTLE RESPONSE, AND THEN THE ENGINE SHUTS OFF.CYCLE THE KEY,HIT THE GLOW FOR A SEC ,THEN SHE FIRES UP FOR A COUPLE OF SECONDS AND SHUTS DOWN,ON AND ON.I HAVE CHECKED FOR WATER IN DIESEL TANK BY POPING THE DRAIN PLUG-A LITTLE SEDIMENT,RUST AND SOME DROPS OF WATER.NOT ENOUGH TO KEEP STALLING THE ENGINE AND NOT LET THE ALT. CHARGE! THE MECHANICAL FUEL FUMP FELT ON OCCASION FOREVER TO PRIME,SO I WIRED IN A 4-7 PSI ELECTRIC PUMP,CLOSE TO THE TANK ABOUT A FOOT AWAY AND I'M STILL GETTING THE SAME THING! THE BATTERY IS MAYBE OVER A YEAR OLD ,BUT LESS THAN TWO.AND THE ALTENATOR IS NEW ALSO.IVE BEEN CHECKING ALL GROUNDS,CONNECTIONS,PLUS I HAVE AN OWNERS MANUAL WITH WIRING DIAGRAM ,THERE IS NO FUSE BOX-ONLY 2 15AMP CIRCUIT BREAKERS 1IS FOR THE ELECTRICAL SYSTEM-SENSORS,STARTING,CHARGING.THE OTHER IS FOR THE BLINKERS,4 WAY AND WORK LIGHTS.I HAVE A FEELING IT MAYBE RELATED TO THE GAUGES OR THE CONNECTORS FOR HARNESS.IS THERE ANY SAFETY FEATURES IM MISSING?I KNOW I CAN START IT IN GEAR ALSO, AND I DISCONNECTED THE TURN FLASHER RELAY AND LIGHTS,IT NEEDS ALL NEW LIGHTS ANYWAY.ARE THOSE HARNESSES KNOWN FOR PROBLEMS?THIS IS MY OWN AND I USE IT ALL THE TIME ,ITS REALLY JAMMING ME UP.ANY SUGGESTIONS PLEASE!!!!
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2023 Timpte Hopper Bottom Trailer (A50514)
2023 Timpte Hopper...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
Bush Hog 2615 Batwing Mower (A50514)
Bush Hog 2615...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
