Nh hydraulic fluid in kubota 3pt hitch?
   / Nh hydraulic fluid in kubota 3pt hitch? #1
trotter13
Can I use New Holland hydraulic fuild in my Kubota 2710 3pt hitch?
Or would I be better off using gear oil 80w 90w?
Thanks, Tom
   / Nh hydraulic fluid in kubota 3pt hitch? #2
Are you kidding? The 3-point hitch uses a common oil reservoir with the hydrostatic transmission, power steering, and other hydraulics (front end loader if you have such). You sure don't want to put anything but hydraulic fluid in there. Kubota recommends UDT or Super UDT, but naturally there are others that are acceptable.
   / Nh hydraulic fluid in kubota 3pt hitch? #3
Yikes...80w 90w gear oil... may as well pour a honey and molasses solution in there. Hydo fluid is thin, Bobcat even says automatic transmission fluid can be used in "emergency" situations as a substitute, but also says to drain and flush and add specified fluid as soon as possible.
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
