Nh hydraulic fluid in kubota 3pt hitch?
   / Nh hydraulic fluid in kubota 3pt hitch? #1
trotter13
Can I use New Holland hydraulic fuild in my Kubota 2710 3pt hitch?
Or would I be better off using gear oil 80w 90w?
Thanks, Tom
   / Nh hydraulic fluid in kubota 3pt hitch? #2
Are you kidding? The 3-point hitch uses a common oil reservoir with the hydrostatic transmission, power steering, and other hydraulics (front end loader if you have such). You sure don't want to put anything but hydraulic fluid in there. Kubota recommends UDT or Super UDT, but naturally there are others that are acceptable.
   / Nh hydraulic fluid in kubota 3pt hitch? #3
Yikes...80w 90w gear oil... may as well pour a honey and molasses solution in there. Hydo fluid is thin, Bobcat even says automatic transmission fluid can be used in "emergency" situations as a substitute, but also says to drain and flush and add specified fluid as soon as possible.
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
Case IH Patriot 3250 (A50123)
Case IH Patriot...
