NH bale wagon belt replacement
   / NH bale wagon belt replacement #1
Farmernez
1971 Case 770
I have a NH 1003 bale wagon and it needs a new pickup belt. I put the last one on about 25 yrs ago and do not remember how I did it. Has anyone done this job in the recent past? It looks like the end of the shaft that drives it must have a movable bearing at the 90 degree gear box which would allow the belt to get over the end of the shaft. Any help or suggestions would be appreciated.
Thanks,
Farmernez
I did replace the belt. I had to remove the bearing bolts on each end and also remove other supportsthat allowed the belt to go on the front end of the shaft. I then had to remove the rear support bolt from the arm holding the pickup head to pass the belt over the arm. Then erverse the process and run the belt over the pulleys and ajust them. And it all worked fine.
Farmernez
16ft x 8ft Flat Bed (A57453)
16ft x 8ft Flat...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
Giyi Mini 39" Vibratory Roller (A57149)
Giyi Mini 39"...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
