NH 930B Finishing Mower wheel/tire assembly.
   / NH 930B Finishing Mower wheel/tire assembly. #1
corwin5
Westminster, Maryland
TC29D
Folks,
Good morning.
I'm in need of a new tire & wheel assembly for my NH 930B finishing mower. I'd like to purchase a replacement for the original NH wheel, since the one that I'm currently looking at simply separated at the wheel/hub weld.
I'm not impressed with the quality of the factory wheel/tire assembly and am considering replacing the set of 4 at once, if I can find a set that appears to be more rugged. The tire is a 4.10/3.50-4 10" tire and is on a wheel that is approx. 3.375" in width with an axle hole diameter of approx. 0.62" (w/o the NH-supplied sleeve insert). This appears to be a standard size tire and is available on sites like www.northerntool.com and others, but I'm unsure of the wheel. Has anyone successfully ordered replacement wheel/tire assemblies from other sites? I'd actually like to get solid tires, since the ones on this finishing mower have needed air added to them on a fairly regularly basis.
Thanks for any info,
Rob
   / NH 930B Finishing Mower wheel/tire assembly. #2
I replaced my solid rubber tires on my mower with air-filled ones from Northern years ago and have had no problems. You have to watch out though and be sure not to oder wheels that are offset - essentially ones made for hand trucks, carts and other similar applications.
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2022 KMC 21-39-HD LOT IDENTIFIER 183 (A53084)
2022 KMC 21-39-HD...
2024 KMC 7406 LOT IDENTIFIER 11 (A53084)
2024 KMC 7406 LOT...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
UNUSED FUTURE CG34 - 34" HYD CLAMP GRABBER (A51248)
UNUSED FUTURE CG34...
KMC 5610 LOT IDENTIFIER 33 (A53084)
KMC 5610 LOT...
