Powerhorse
Bronze Member
Hey everybody,
A few weeks ago I was using my backhoe to move my shed and had a hydraulic hose blow on the boom. I decided to replace all the hoses on the boom, dipper and bucket cylinders. I took all 6 hoses off and capped the cylinders and valves to keep oil from leaking out. I took the hoses to a hydraulic hose shop and left them with the shop so they could duplicate them. I got them back the other day and installed them today. Now for my problem. I seem to be having an issue with the bucket curl and dump moving very slow and have a fluid rushing sound and the cylinder. I had the same issue with the dipper but that seems to have worked itself out. The bucket is faster to curl then dump but both directions are slower than before. I have cycled all the cylinders from end to end. I loosened and checked the fitting on the bucket cylinder with the rushing sound and didn't see any issue. I reconnected the fitting and the problem continues.
The hose shop used 1/4" or 6.4mm 3000 psi hose with Eaton fittings that matched my hoses. All other hydraulics seem to work fine. Any ideas on this would be appreciated.
Thank You
Thank You
