NH 66 baler
   / NH 66 baler #1
elrancho
Need some help. Getting loose bales. what should I check. I have a manual but very general info.
thanks,
roberto
   / NH 66 baler #2
:welcome:
Are you familiar with the adjustments needed and they just don't work, or just not familiar with how it works?
Thinking first that the springs are not tight (enough).
   / NH 66 baler #3
Crank those 2 springs down at the back of the bale chamber. If that don't work,may need to do some inside chamber work. Ken Sweet
   / NH 66 baler
I tighten the springs on the back, helped a little. put still loose.
chains are alittle loose put not very much. What would I have to do inside the chamber?
   / NH 66 baler #5
What stopped you from tightening the springs more?
   / NH 66 baler
i tighten them dwn as far it would go and still loose.
   / NH 66 baler #8
The bale wedges are internal V pieces that hold the bales back somewhat for resistance. Ken Sweet
   / NH 66 baler
ken, I will look into the wedges. thanks for your quick replys.
should I clear out the last bale of leave till I bale again.
thanks
Roberto
   / NH 66 baler #10
Most farmers get the last one that is out of the chamber and leave the rest until next time. Keep baler in a shed out of the rain between uses. Ken Sweet
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2021 Chevrolet Express 2500 Cargo Van (A51692)
2021 Chevrolet...
J and L Cargo Express Shadowmaster Enclosed Trailer (A53473)
J and L Cargo...
377811 (A48836)
377811 (A48836)
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
