NH 555E brake issues
   / NH 555E brake issues #1
gagnon07
new holland 555e
I have a 2000 NH 555E 4x4. The right brake pedal has always been hard to push since I bought the machine, so I generally just use the left pedal. Occasionally I will forget and push the right pedal. when I do this, the right rear wheel will lock up, and it will take a bit to get it free... any suggestions of where to start? thanks!
   / NH 555E brake issues #2
Sounds like the brake piston is hanging up in the housing. You could temporarily swap the brake lines on the master cylinders and try pumping the brakes. That would eliminate the master cylinders.
After that, you'll have to pull the axle and inspect.
Spray Rig And Storage Boxes (A50860)
Spray Rig And...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2013 GMC Sierra 2500HD 4WD Pickup Truck (A50860)
2013 GMC Sierra...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
