Mowing NH 451 cam shaft pin replacement
   / NH 451 cam shaft pin replacement #1
SEMPER FI FARMER
Nokesville, Virginia
1978 Ford 3600 / 2004 NH TN70/DA
I have been looking over 2 of the mowers I bought. 1 needs a new cam shaft pin and the other would not hurt to change if I can. In the parts break down I looked at with a dealer seemed like the cam shaft and pin were two different part numbers. One like 490. And the other "pin" was 70 something, so I would like to change out the pin on both or do the entire cam and pin on just 1. Has any body ever done this and if so how do you change out just the pin? Just to make clear the cam is what the pivot joints connect to from the belt pully which drives the other pivots to drive the sickle. Hope someone has done this, hate to soon be the only one.
Andrew
I misspoke, it is a crankshaft, item number 4 in the messick's diagram, item number 5 is the pin, item 4 comes with all together. I want to figure out how 5 fits into 4.
thank you,
Andrew
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
RoGator RG1100C (A52748)
RoGator RG1100C...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2013 Cadillac Escalade Luxury SUV (A50324)
2013 Cadillac...
