NH #3930 PTO HAS QUIT
   / NH #3930 PTO HAS QUIT #11
Try disconnecting the engagement lever from the splined shaft, rotate a little, then reconnect it.. might give a little more life to a damaged clutch. If that works then fine-tune adjust it to where engagement takes place at about 2/3's of the throw distance between stopped and spinning, then re-adjustment the "slip" bump stop.
That lever is worrisome, I've never left mine at the "slip" detent, but I have knocked it off of full engagement many times with my leg.
   / NH #3930 PTO HAS QUIT #12
That's absurd. Do you have any idea how the PTO clutch on a 3930 works? The lever operates a hydraulic control valve spool. Altering the stroke of the spool can do nothing but degrade clutch operation, one way or the other.
   / NH #3930 PTO HAS QUIT #13
Just started having issues with my 3930's pto as I started to use a bushog the other day. Engaged pto and it quickly disengaged and would not attempt to come back. Now I have noticed the 3 point lift is not working either. I have herd of these shafts breaking in these tractors. Could someone give me information on the trouble shooting the hydraulic pto drive system. Praying I can rule a broken shaft out and move on to a simple relief or something. Thanks for any advise.
   / NH #3930 PTO HAS QUIT #14
you have tagged onto a 7 year old thread. you will get more hits if you start your very own new thread!
   / NH #3930 PTO HAS QUIT #15
I was hoping it would notify one of the previous posters and they could help me out with the issue. I have started one in the parts and repair with no reply.
   / NH #3930 PTO HAS QUIT #16
i think i'd have started one in the NH section, since it is a NH tractor!
As for previous posters, depends on if they were set to subscribe to the thread, or if they removed the subscription, .. or if they are still here.. ( one of the guys for sure is )... but remember.. 7 years is a loooong time.
   / NH #3930 PTO HAS QUIT #17
Hey! That's a good idea an will do that. Thanks.
   / NH #3930 PTO HAS QUIT #18
however.. i doubt you will get much better advice than you are already getting on the ford forum at ytmag. ( ps.. rickb is a member here and there... but sean is pointing you in the right direction.. check hyd fluid, then pressure.. do you have remotes? )
   / NH #3930 PTO HAS QUIT #19
Checked fluid. Going to check pressures this afternoon. I have two remotes and both are working well. Just lift and pto giving problem.
   / NH #3930 PTO HAS QUIT #20
2 pump system or 1?
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2020 INTERNATIONAL...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
VIDEO LINKS FOR ALL LOTS W/ VIDEOS (A59213)
VIDEO LINKS FOR...
