Mowing nh 273 baler disc will not hold twine
   / nh 273 baler disc will not hold twine #1
bimlay69
clinton,ohio
john deere
nh 273 baler disc will not hold twine then comes out of bale hooks stays connected to last bale continues out the chute then i have to rethread bale hook start over until it happens again does it about every 10 or so bales
   / nh 273 baler disc will not hold twine #2
Not enough info to say exactly. Worn twine discs/holder. Weak/broken/maladjusted twine holder spring. Get out your operator's manual and read up on knotter troubleshooting. If you don't have an operator's manual, buy one here:
Choose Items
Item 42027315 in hard copy or pdf download. Best $20 you will ever spend on that baler.
   / nh 273 baler disc will not hold twine #3
Have you greased the knotters recently? Our 273 will start to not release the knots if its not greased regularly.
Aaron Z
   / nh 273 baler disc will not hold twine #4
Are you using square bale twine ? If it's plastic, you may have picked up balls of round bale twine. If it's sisal, the twine may not be the proper thickness. Twine disc tension is adjustable
it is 9000 ft sisal having problems with only one side baled about 130 bales then started acting up right side works well i did notice that little pieces of twine was building up on the chamber under the left disc
   / nh 273 baler disc will not hold twine #6
Could also be that the needle isn't consistently delivering twine to the disc or bill hook. Needle adjustment, twine disc timing, broken hay dogs and/or hay dog spring. Twine finger out of adjustment.
That's why I suggested a manual. go through the systematic knotter adjustments IN THE PUBLISHED ORDER.
I have the manual could not find systematic knotter adjustments do not know what i am missing
43055 (A55851)
43055 (A55851)
Teak Wood Dining Table (A59231)
Teak Wood Dining...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
LOAD OUT AND SHIPPING (A57453)
LOAD OUT AND...
43001 (A59228)
43001 (A59228)
