NH 269 Plunger bearing removal
   / NH 269 Plunger bearing removal #1
bjr
Veteran Member
Eastern WA
Jinma JM354
Plunger is out of machine setting on a pallet.
These bearing are shown as item 10 on the parts page. There is also a pipe plug shown in the ends of the bearings. The issue is removal. There's a 3/16" allen wrench head (socket head) in the end but I can't get them to budge. Any tips or tricks to get these bearing off the studs. The stud if ordered is shown at $84.56 I think it takes 6 of these, kinda spendy. Help on bearing removal is appreciated. And yes I have the "operators Manual" but not much help on this problem. bjr
   / NH 269 Plunger bearing removal #2
Heating the stud should help. Are you using a standard allen wrench or a socket type? Socket allows more torque to be applied.
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
