NH 268 hayliner. time for knotter rebuilds. Anyone doing exchanges/core? kits?
   / NH 268 hayliner. time for knotter rebuilds. Anyone doing exchanges/core? kits?
couple updates... The parts all went in just fine. I used my rolling garage hoist to hold/lower the stack back into position and get buttoned back in.. I thought that worked out well. Today will be greasing, resetting the timing, end-play, twine finger, plunger/needle check, blah blah. Essentially run thru the manual... does not take too long. especially when it's all clean.
The coolest adjustment I learned was the 'knife arm' travel and adjustment... essentially get a big ol' crescent and bend as required this way and that. W/ the new billhooks in... was absolutely needed ;-0
   / NH 268 hayliner. time for knotter rebuilds. Anyone doing exchanges/core? kits? #12
Always fun to see the look on a customers face when I started beating and bending on a brand new knife arm.
Keep us posted!
OKy - short update- Ran thru some tests of all equipment today. have a new Orange M6060 as an update to the L2550Gst. Everything is different, and just different settings and setups end to end.
On the whole Knotter rebuild - Simply put: beautiful knots! Not a miss.. not a glitch and overall... this was actually easier than I thought it would be. (a few pics below).
lessons learned-
I really did not need to pull the entire stack off the frame. the knotter service manuals details how to remove about everything w/o pulling it.
Misses GC told me to keep notes. which actually helped! Usually I just shoot pics, but notes did help!
To work on it; I set the stack on end in a workmate... (pic below) which really makes it easy to slip the knotters on/off. (dis-assy/assy)
It's heavy when all loaded back up and to set on the frame was just too much for me - Thus that 2ton garage crane ya'll have too from TSC, HF, RK, ...where-ever - really helped. Just sling it, lay it in and bolt it back up
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
Polaris Ranger (A56859)
Polaris Ranger...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Takeuchi TL10 (A57148)
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
