NH 256 hay rake drive shaft
   / NH 256 hay rake drive shaft #1
amiller7
I need to change out the drive shaft on my NH256 rake. Do I need to remove the shaft from the gear box before hammering out the U-joints? I am told that you could break some teeth on the gears in the gear box if you try to remove the U-joints while the shaft is still mounted on the rake.
Thanks,
Andy
   / NH 256 hay rake drive shaft #2
If you know what you are doing, you can break down the u-joint with the upper yoke/shaft in the box. If you are really handy, you may even be able to do it with the box on the rake. If you go at it like a bull in a china shop, all bets are off.
toro turf sweeper (A50324)
toro turf sweeper...
HYSTER STRAIGHT MAST FORKLIFT (A51246)
HYSTER STRAIGHT...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2025 Mower King SSRC (A50123)
2025 Mower King...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
