TractorTech
Elite Member
- Joined
- Jan 26, 2012
- Messages
- 3,011
- Location
- California
- Tractor
- Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
Okay, I have to admit that you do have to take the top cover/rockshaft assembly off too. The PTO sliding gear is under the top shaft that you can see going over the differential gear. There is probably wear to that shaft and you will have to take that shaft out to remove the sliding gear.
If you turn the shaft over by hand, can you hear grinding behind at that point?
