NH 1920 stuck clutch
   / NH 1920 stuck clutch #1
billfires
Southeastern Mass
New Holland 1920
My 22 year old NH 1920 with 670 hours has been stuck since 2015. The tractor was stored outdoors for the majority of it's life. I have been using it in low range for the past 7 years. Finally towed it to an independent shop where they split the tractor and here is what they found: Estimate is $1200-1400 for a replacement. Bill C
   / NH 1920 stuck clutch #3
I'm assuming that the price includes a new clutch plate and pressure plate, but the disc looks fine.
The pressure plate is rusty, but could be cleaned and the links lubed
   / NH 1920 stuck clutch #4
If you seldom use the tractor get a block of wood and make it so the clutch peddle is pressed down as the tractor sets. Some tractors have a clip that you can hook to the clutch peddle for that purpose. This will help to keep the pressure plate free of the flywheel.
   / NH 1920 stuck clutch #5
from manual
Just an update, total price came to $2869 which included a full service (hydraulic fluid + filter, Oil and filter, repair leaking fuel return line and new filter, lubricate all linkages. Labor was $1250 (16.66 hours @ $75.00/hour). The shaft for the clutch was replaced also. Tractor is now stored in a barn with concrete floor and I will block it with the factory wooden block. Bill C
REDBALL 4R HOODED SPRAYER (A52708)
REDBALL 4R HOODED...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
478 (A52708)
478 (A52708)
Deere 35G (A53317)
Deere 35G (A53317)
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
