NH 1431 DiscBine axle problem
   / NH 1431 DiscBine axle problem #1
VictorianFarms
Randolph,Ohio
White 2-155
1431 discbine that has a tapered in wheel problem on both sides. Nothing is bent but I cant seem to find what actually is causing the problem. I was thinking the bushings might be bad in the control arms. If you look at the pictures, you can see how the position of the cyclinder are in relation to everything else.
   / NH 1431 DiscBine axle problem #2
Either that, the pin worn out or the arm has a twist. My IH 3309 discmower has a similar type of arm in that area but it runs the header lift and the tires are fixed the the frame. The bushings in the arms are ok but the pins are worn out badly. One has a tractor hitch pin in it from the previous owners field repairs.
   / NH 1431 DiscBine axle problem #3
G'day I would say a combination of worn pins/bushes and the rail that the bushing mount is in looks twisted as well
Jon
UNUSED FUTURE VR72 72" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR72...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
