Nh 1033 bales tipping on 2nd table. advice
   / Nh 1033 bales tipping on 2nd table. advice #1
Hiawatha22
Saskatchewan
Hello, just starting to use my bale wagon. bales are 36 inches solid tight heavy and uniform. When the 1st table trips and puts the 3 bales onto the second deck the left bale (chute side) wants to tip backwards onto the second table rather than staying on 1/4 turn like the others. Field is not rough and was travelling in that 3 mph range. I notice that the left side of the second table does not sit down tight on the frame or on the rubber bumper on that side, not sure if something is bent but the second table on the left is almost an inch higher than the right when in down position, could this be it? Also read now in the manual to adjust first table trip travel, thought that might help. Looking for someone who has been down this road before. Thanks.
   / Nh 1033 bales tipping on 2nd table. advice #2
You might try adjusting first table to trip earlier in cycle. My 1033 does the same thing when going up a hill. Sometimes lowering engine RPM when table trips will help.
LOT OF 7" CHANNEL IRON (A58374)
LOT OF 7" CHANNEL...
4 SEMI MOTOR SHIPPING BLOCKS (A58216)
4 SEMI MOTOR...
JOHN DEERE 68 FEED CART (A52708)
JOHN DEERE 68 FEED...
TANK MANIFOLD (A58214)
HUSQVARNA PUSH MOWER (A58374)
HUSQVARNA PUSH...
TROYBILT TILLER, TINE TILLER, DEER STAND (A58374)
TROYBILT TILLER...
