NF1233?
   / NF1233? #1
rlee6
Central Florida
Allmand 8435 HST (TYM T330 HST)
A local newspaper has MF1233, 200 hours, $5500. I cannot find mf1233 on internet. What is it? Thanks.
FYI: 1230 is 25 hp, 1235 is 30 hp.
   / NF1233? #2
rlee6, According to the reading I just did it is a 28hp tractor in the popular 1200 series... With 200 hrs. if it looks good and operates properly and it fits you satisfactorly, I would probably get it... At that price it doesn't sound like it has a loader but WOW if it did /forums/images/graemlins/smile.gif That would be a steal....IMHO /forums/images/graemlins/smirk.gif
   / NF1233? #3
I hadn't said anything because I couldn't remember a 1233. Nasty are you sure that it wasn't a 1433 that you were looking at? I looked through my manuals and couldn't find a 1233, but I may be blind> /forums/images/graemlins/blush.gif
   / NF1233? #4
Yes, there was a 1233 that came out a little later than the 1230 and 1235. I have a brochure with it in it.
   / NF1233? #5
It was replaced by a 1428v.
   / NF1233? #6
Here's some info. on MF 1233...
MF 1233:
Eng HP = 28.4 @ 2500 rpm
PTO HP = 24.1 @ 2500 rpm
STD gear transmission only, NO hydro option
displacement = 89.3 (1.5 L)
foward speeds = 1.2 - 13.5 mph
reverse speeds = 1.2 - 6.8 mph
lift capacity @ link ends = 1,984 lbs.
" " 24" behind link ends = 1,201 lbs.
Hydraulics- total system flow = 8.5 gpm
Weight:
2wd = 1,808 lbs.
4wd = 1,984 lbs.
wheelbase = 64.6"
overall lenght = 116.5"
minimum width = 55.5"
height over ROPS = 78.3"
   / NF1233? #7
After I posted that a while, I got to thinking that I had made a note in one of my manuals about a 1233. Sure enough I did. /forums/images/graemlins/blush.gif
   / NF1233?
Thanks for the info. I googled for it but didn't find much. No, it does not have FEL, a bare tractor. The price seems reasonable and I will purse it. Thanks again.
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
8" & 10" I BEAMS & 6" & 8" CHANNEL IRON UP TO 25' (A51247)
8" & 10" I BEAMS &...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
UNUSED FUTURE FT-XGJ 40" HYD ROTARY TILLER (A51248)
UNUSED FUTURE...
