Buying Advice Newholland round baler numbers
   / Newholland round baler numbers #1
AdamM
TN75DA
I'm not sure if this is the right place but I may be in the market for a new round baler soon and was wondering what all the numbers mean?
I'm looking for a 4x5 baler and was looking at a 450 roll belt. Is there any other nh balers I should look at and is there an option that's a must I should opt for?
I have an 853 chain and bar right now that's a great baler but just too big for me so I want a 4x5.
Thanks,
Adam
   / Newholland round baler numbers #2
Thanks,
Adam
a br7060 is also a 4x5 baler but on it you can get auto wrap or net i dont believe the 450 roll belt can have net wrap i know they dont have auto wrap. If baling alot of hay say over 100 rolls a year i would suggest a br7060 with auto wrap they have made this same baler since i believe 1992 they only changes have been the model number and seat metal and the lower idler gear on the rollers was upgrade in the middle of production of the 648 which is what i have and love it. If you have never run a autowrap baler you will love it to all you have to do is open and close the tail gate no messing with the remotes or electronics to make it tie
   / Newholland round baler numbers #3
You can get net on a 450, but the two 450's we sold last year were twine only. I also prefer the BR7060 for that size bale, but after being skeptical of the looks of the 450, they performed well and impressed me in their first season. The 450 is a great improvement over the 630/634/638/BR730/BR7050 machine they replace.
I thought the 450 had auto tie?
   / Newholland round baler numbers #5
The 450 does have an automatic electric tie system. It does not have Autowrap, which is a specific automatic, fully mechanical twine tie system that is available on basic BR7060 and larger NH balers. Autowrap has its roots in the older NH chain style balers and is a very reliable system.
This may be a stupid question but can you explain the difference? I'm kinda new to this.
   / Newholland round baler numbers #7
The electric tie system on the RB450 and other New Holland balers using any version of the Bale Command electronic system use an electric linear actuator to move the twine arms across the bale chamber width. Most manufacturers use some version of this system.
Autowap uses a belt driven 90 degree gearbox and open spur gears to move the twine arms, taking power from the baler's mechanical drive system. I don't know of any other manufacturer that uses a fully mechanical twine tie system like this. If there is any, someone will surely point it out to us shortly.
So do both automatically tie?
On my 853 I stop, push a switch to run the arms out to tie. I'm thinkin that I won't have to do this with the 450 or a 7060 right?
   / Newholland round baler numbers #9
That is correct no matter which system you are considering.
The reason I was looking at a 450 was for the price. I can get a new one with a bale kicker for 15,600. The 7060's are quite a bit more. Is there a big difference between the 2? Is the 7060 made better? I'd rather spend a little more now than to have problems later.
Thanks
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
New Holland B95 Backhoe (A50490)
New Holland B95...
John Deere 6115D (A50120)
John Deere 6115D...
Ashland 5 yrd Dirt Scraper (A50515)
Ashland 5 yrd Dirt...
2016 Kubota SSV75 Skidloader (RIDE AND DRIVE) (A50774)
2016 Kubota SSV75...
