Newholland clutch adjustment
   / Newholland clutch adjustment #1
Mikmas76
Kitale, Kenya
Newholland and Massey
Hi members,
I've got a NewHolland TT75, I replaced a clutch disc but the issue is when I engage a reverse or first forward gear, it produces a noise(like a brake jam) inside the clutch, but goes off immediately I fully releases the clutch pedal. Does it mean that I did wrong clutch adjustment of the fingers and if so can some one assist me a link with the procedure of how i can make the correct adjustment.
Thanks in advance for your assistance.
Mikmas
   / Newholland clutch adjustment #2
Did you replace the gearbox inputseals aswell...maybe there s a c-clip left outside....or the clutchdisc is the wrongway in ?
Thanks Mr DLYTrekkers, I had replaced the input seals. Ok, after inspecting the flywheel and the pressure plate I realized that they were worn out, I therefore replaced both and now the he machine is working well.
Thanks for your contribution
   / Newholland clutch adjustment #4
How do you adjust a clutch on a TN60 New Holland?
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
