Newholland clutch adjustment
   / Newholland clutch adjustment #1
Mikmas76
Kitale, Kenya
Newholland and Massey
Hi members,
I've got a NewHolland TT75, I replaced a clutch disc but the issue is when I engage a reverse or first forward gear, it produces a noise(like a brake jam) inside the clutch, but goes off immediately I fully releases the clutch pedal. Does it mean that I did wrong clutch adjustment of the fingers and if so can some one assist me a link with the procedure of how i can make the correct adjustment.
Thanks in advance for your assistance.
Mikmas
   / Newholland clutch adjustment #2
Did you replace the gearbox inputseals aswell...maybe there s a c-clip left outside....or the clutchdisc is the wrongway in ?
Thanks Mr DLYTrekkers, I had replaced the input seals. Ok, after inspecting the flywheel and the pressure plate I realized that they were worn out, I therefore replaced both and now the he machine is working well.
Thanks for your contribution
   / Newholland clutch adjustment #4
How do you adjust a clutch on a TN60 New Holland?
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
LMC G300JD LOT IDENTIFIER 230 (A53084)
LMC G300JD LOT...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
