NewHolland 21D
   / NewHolland 21D #1
L98camino
Central Wa.
None
Hey guys, had an accident and had to leave the tractor on it’s side on a downhill slope for a few days. Got it hauled up yesterday. What kind of precaution should I take before trying to start it.
thanks, Dan
   / NewHolland 21D #2
thanks, Dan
Check all the fluid levels (engine oil, coolant, fuel, transmission fluid and hydraulic fluid, front axle fluid, battery electrolyte). Top off as required. Pull plugs or injectors to make sure that there is no oil in cylinders. If there is, crank to clear and re-install plugs or injectors.
Check all the wiring connectors and look for broken wires. Repair as necessary.
Check engine control linkage for damage and restore.
Bleed fuel delivery system if you have a diesel. Then try to start.
Look for fluid leaks and damaged components.
   / NewHolland 21D
Trying to register with MyNewHolland.com. Need some service info but the site won’t take any of the numbers I have found.
2006 TC21D
   / NewHolland 21D #5
What are you trying to find on MyNewHolland.com? You don't need to register to get most everything on there
   / NewHolland 21D
The site requires serial number and it won’t take any of the numbers I have
   / NewHolland 21D
I’m looking for service manuals and part diagrams
   / NewHolland 21D #8
Operator Manual:
Service Manual:
Messick's normally has a good selection of parts and diagrams online:
   / NewHolland 21D #9
Just wondering, but it is a TC21D, not 21D. That might be the reason it won't take it
1268 (A50490)
1268 (A50490)
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
VERMEER S925TX STAND ON SKID STEER (A51242)
VERMEER S925TX...
2006 Ford F-150 Pickup Truck (A50323)
2006 Ford F-150...
Vermeer 840 Discbine (A50774)
Vermeer 840...
