newer jd rider mower blade nut ?
   / newer jd rider mower blade nut ? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
neighbor has begged me into helping him change the blades on his newish ( 2-3 ys old? ) JD rider mower. guess he's tired of paying the 200$ pickup and change charge for a 40$ set of blades. He has no tools.. even borrows my grease gun once a year to grease the zerk on his gate.
anywho. we are neighbors so you know how that goes. I need to keep him happy as my farm maintenance isn't as perfect as his acres of finish mowed lawn.. and non stop ;andscaping since he is semi retired..
can i assume the nuts are standard left-loose, right-tight, IE,, tighten against the direction the blade travels, IE.. when cutting it's 'tightening' the nut.. like one would normally expect... or am I gonna find something weird under there.
he's suposed to come over tomorrow am when I go out to feed the animals before work.. so I don't have much time to dink around. I already got the tractor with laoder and chain and strap parked there to lift it, plus stands and ramps, will turn the compressor on in the barn first thing, and have my air guns set out.. pretty sure a 3/8 won't do it.. but have the 1/2 and big :) 3/4 ready...
any idea the size of the nut.. I'd like to have all the tools ready to go when he drives up so I can yank it up in the air spin the nuts off, yank old blades, slap the new ones on, and spin the nuts back on.
what torque value? I have a clicker wrench.
On my old beater murray, Ijust buzz em on and off and don't worry about torque. had one spindle strip and gall long ago from a stainless stell nut the manufacturer used :( rethreaded that spindle.. so I'm always carefull with it.
as this is a nicer JD mower.. I'd like to have my ducks in a row, get him in and out fast, so I can go to work. I don't want him leaning over the fence trying to catch me all next week when I'll be even busy-er. He kept offering to pay me.. but IMHO.. I just want to get it done.. and won't be accepting any money. Last month he had a stump in his fenceline I helped him dig out. in the process we broke one of my old shovels. no biggie.. it was 15ys old. I told him REALLY don't worry about it.. so yesterday when he asks me about the mower blades he hands me a new shovel ARGH! I now feel obligated.. ;)
nut size? and I'm correct on standard right tight for that mower.. nothing alien under them high dollar units?
soundguy
   / newer jd rider mower blade nut ? #2
Yeah nothing alien under there. I forget the size of the bolt, 11/16 maybe? it is a standard right hand thread on both sides, I just use a block of wood keep the blade from turning and breaker bar loosen and tighten.
i'll ighten with a BB and a torque wrench to check.. but to remove i'll buzz off with an impact gun.
thanks for the heads up..
soundguy
   / newer jd rider mower blade nut ? #4
Under mine I found 15/16 fine thread RH nuts with a dimple and a cupped washer. I threw the dimpled lock nuts at a jack rabbit (missed with both) before they screwed (pun intended) up the shaft threads and replaced with standard nuts. They are so easy I don't bother raising it up. About 5 minutes / blade (42 incher) torque to about 60 by experienced feel and I'm done. And that includes 2 drops of oil on the nut threads off the end of the dipstick.
   / newer jd rider mower blade nut ? #5
15/16 standard direction is what most mowers I have worked on are (Kubota B and BX decks are just over an inch, byt they are an exception).
Aaron Z
   / newer jd rider mower blade nut ? #6
Deere is all metric, and under the 54" mower decks of my 455 and X485 the blades are a bolt (not a nut) that takes 18mm socket or box end wrench. It is a 12mm x 25mm bolt (screw by jd parts)
An 11/16" doesn't go on. With some grass juice build-up, the 18mm is usually a press fit tho.
Don't know what SandburRanch has, but I wouldn't toss out the dimpled cupped washers as they hold things on tight. Just be sure they go on the right direction :)
The 60" deck has a 16 x 60 bolt holding the blade on which takes a 24mm metric socket or wrench.
Soundguy, which deck does your neighbor have? The blades throw the grass to the right so the standard thread tightens the bolt when it loads up.
this was some sort of 3xx series.. and it ended up having a 11/16 bolt. had to scrape dirt and crud off to find em.
went on and off without a hitch.. lifted with tractor.. speun em off.. toqued em back on.. goot to go.. neighbor mowed for 3 hours after that.. no complaints.
glad too.. :)
soundguy
2019 POLARIS RANGER XP1000 RTV (A51406)
2019 POLARIS...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
