Newbie with 1995 425 AWS
   / Newbie with 1995 425 AWS #1
Foxgap1
Bangor. PA
John Deere 425 All Wheel Steer
I found this forum while looking for answers to a few problems on my 425 AWS serial # M00425B021944. The tractor has about 1800 hours on it. According my mechanic the motor is starting to get tired, 130#s of compression but will last a bit longer before a replacement is due.
The biggest problem I have always had is that after shutting off the motor and letting it sit for awhile and trying to restart it. It seems as though the fuel boils and floods the motor making it difficult to start. I have been told there is a replacement carb that does not have this problem but have yet to confirm this or get a part number. Is there a possible fix to the original carb that is on it now? Opening the hood at the time I shut it off seems to help restarting it after about 15 to 30 min. It seems to relieve the heat around the engine. Also washing the motor down, especially the carb after mowing also helps. I seems the dust collects on the carb and causes it to retain heat. Wash the dirt off and the tractor runs much better.
Recent repairs have been
Power steering cylinder and both hoses
Starter
Time delay module
AWS linkage
Coming up repairs
NEW SEAT!!!!!
Replacement hood
Rebuilt Kawasaki motor
New set of rear tires
   / Newbie with 1995 425 AWS #2
Welcome to TBN, Foxgap1.
   / Newbie with 1995 425 AWS #3
Welcome to TBN and I hope someone can help you find fixes.
   / Newbie with 1995 425 AWS #4
:welcome: to TBN...enjoy.
   / Newbie with 1995 425 AWS #5
Foxgap1, welcome to TBN. I have a JD 325 lawn tractor that had symptoms similar to yours . If you are unsure about the fueling, remove the plugs and check to see if flooded. If the plugs are dry, you may have the same issue I had - a bad coil and/or igniter. Replaced both and now it starts hot or cold every time.
   / Newbie with 1995 425 AWS #6
Have you ever replaced the fuel shutoff solenoid?
That shuts off the fuel supply to the carburetor.
Part # AM118873
That s/n is a 1994 number.. I believe.
I have not replace that part, thought about it, but did not do it yet. I would imagine since it seems to be flooding when hot it may be bad. I will put it on my list of things to do this coming week.
Thanks for the suggestion!!!!
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
