Newbie very confused
   / Newbie very confused #1
lilyperch
Herrick, IL
2016 Kioti NX4510 HST Cab Backhoe
Looking at ne Mahindra 2555 hst with fel backhoe and hydraulic thumb and kubotanM4800 or 5200 with backhoe. Also will be getting a grapple. Will be using scraper, box scraper and a pull behind 1-2 yd dirt scoop.
Options available 3rd function?? spool valve??? extra remote??? etc What are they for? Are they needed??
What is necessary or unnecessary??
Thank you,
   / Newbie very confused #2
They are the hydraulic equivalent of an electrical outlet and switch. If you had a table saw, miter saw, drill press, and sander, would you want a workshop with only four outlets?
Many tractors only have valves and connections for the necessary loader and backhoe functions.
Want a hydraulic thumb? No place to plug it in.
Want a grapple? No place to plug it in.
Want top and tilt on your hitch? No place to plug it in.
Hydraulic cylinder or two on an implement? No place to plug it in.
Get all you can. :)
Bruce
   / Newbie very confused #3
I'm a hydraulic noob too, so value any of my advice commensurate with what you paid for it.
For a grapple, you'll probably want a "3rd Function" control mounted on the FEL joystick. So that's one complete circuit and set of parts/controls.
For rear remotes, the widely acknowledged "necessity" is a top and tilt pair of rear cylinders, which will require one control valve each, usually stacked. The "top" cylinder replaces your top link; the "tilt" cylinder replaces one of your side/lift arm links. Get valves that have a float/detent if possible so that you have the capability to lock them in the "on" position for some other rear implement that requires constant flow (like a splitter). If you're adding two rear remotes, it is usually not a lot more $ to just get 3. Less $ and hassle than if you later decide you need to add a 3rd. Your backhoe should mean that the tractor already comes equipped with either PTO-powered hydraulics for the hoe, or at least one rear remote circuit.
You'll usually spend a lot less if you can buy all your accessory hydraulics as a "package" from the dealer at the time of original sale. That said, you'll usually spend a lot MORE for factory/OEM parts than for aftermarket stuff. But the factory stuff will generally fit and will integrate in with your tractor best. If resale value is important to you, factory, integrated setups will likely command a premium.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52128)
2018 Rock Solid...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Online Buyers Premium (A47384)
Online Buyers...
